I am replacing intake on vortec head 5.7engine. Has anyone used the Fel pro MS98000T gasket for this? Instead of the usual plastic carrier and thin sealing bead, it is a metal core with substantially more rubber sealing the ports. Looks like a lot better gasket, but I cant find if the carrier is aluminum, steel, stainless etc. The entire externally exposed part of the gasket is rubber coated, so I dont think there would be any corrosion concerns, but looking for other opinions.
Fel-Pro MS98000T - Intake Manifold Gasket Set | O'Reilly Auto Parts
