Interchange of parts from a 93 to a 95 Merc 75HP
indyboy
Hi everyone... I have a 1995 Merc 75HP with a bad lower engine bearing. I found a 1993 75 HP Merc that runs great and is cheap..1K with controls and trim and tilt work great. Compression is 120 per cylinder. Would most ..if not all.. of this motor bolt right on to the 1995 that I have? Thanks in advance!
Faztbullet
Only thing that may be different as 93 is around the year they went from a 3 jaw to 6 jaw clutch dog, and shift linkage is different between the two
Texasmark
You can tell on the clutch dog by looking at the midsection casting. From the rear of the engine with your head immediately above the protrusion of the mid section as it goes back over the prop and just above where the midsection and the LU mate, is a little flat place in the casting about half an inch square. If the mark is square it's a 3 pin/socket dog for R gear. If it has a 45 degree right triangle geometry it has the 6 pin/socket. From an operator's stand point you probably won't notice the difference unless you do a lot of sloppy shifting into R. 6 doubles the surfaces to wear off the corners and kick out of gear.
On linkage, I guess Faztbullet is talking about within the engine; not as it adapts to the remotes. The Commander 2000 and 3000 remotes should mount right up if your electrical connector is the same 8 pin circular connector.
