Thought I'd throw this out and see if anyone else has seen it. While rebuilding the carbs. on a 1989 Johnson 100 (J100STLCEM) I found the upper carb had 2 different size idle bleed air orifices installed. The Lt. throat of upper carb. has a #38 & the Rt. has a #20. The lwr carb. has #38 in both sides. I cant say that I've noticed any real idle problems. I only ran it about an hour since I've owned it. Not the first time the carbs. have been opened either.(Previous owner?)I'm not against ordering another orifice when I buy my kits just not sure if they should all be the same size. The manual just says to note the size when you remove them.
