centerline
- Sep 8, 2008
- 57
OK, that serial number looks to be a 4 cylinder Merc 850, from 1975. Spark Plugs should be NGK BUHW. Remove, clean and rebuild the carbs with new gaskets, floats, inlet needles and seats, or at least inspect them to make sure the mechanic did it.
Invert the carb bowl cover and see if the float levers are parallel with the cover. That is the proper adjustment. Make sure the float is hard plastic and has the little spring on top. Clean or replace the banjo filter in the cover over the carb bowl cover.
Initial idle mixture adjustment is 1-1/2 turns open. Final mixture must be set on the water, at idle, warm engine, fresh fuel mixture.
It probably makes sense to get a service manual, so you can check the timing as well.
the sparkPlugs are NGK BUHW..
I have a seloc service manual... as decent as I thought seloc was, the seloc manual for my 4.5hp has very confusing/wrong information in it about the 4.5... I will be finding out how the manual for the 850 works for me...
