I am having a very intermittent alarm on my 2007 4.3 tks. I have narrowed the alarm down to the temperature sensor on the thermostat housing. It is the one with 2 wires, 1 yellow and 1 black, not the single wire sending unit. When unplugged the intermittent alarm is gone and when plugged in it is intermittent while underway at half throttle and up. Is there a way to test this sensor? My continuity bench test shows 1900 and when I dip it in 180F water it is around 300. I thought this sensor was either open or closed.
My temperature on the gauge is 170F and the thermostat housing is 160 when tested with a IR gun.
Should I replace the sensor, or thermostat, sensor and impeller? I changed the impeller approx. 3 years ago and only put around 10 hours on the boat per season.
Thanks for any help. I cant seem to find any manuals that show this type of alarm setup. All of the manuals seem to have a single wire sensor for the guardian alarm.
