1979checkmate
- Jan 15, 2011
- 261
Okay, 1979 115 hp mercury inline 6. Cd distributorless ignition. I seam to have a no spark/ intermittent spark issue on cylinder 2. A little more background: i have replaced the stator and trigger with new CDI parts. One switchbox was bad so i replaced it with a working used one. I switched around cylinder 1 and cylinder 2 coils and the problem does not seam to follow the coil or spark plug wire. Cylinder 2 seams to be the only cylinder not firing. I hooked up and inductive timing light to cylinder 2 and ran the motor, the light does go off indicating a spark once in a while, but not nearly as often as it should. ANybody have any idea what could be the problem?
