Introduction - New owner 16' Lone Star Runabout
Kohrah
Greetings,
I just purchased a 16' Lone Star Runabout with a fiberglass hull. It has a 75hp Johnson outboard motor. The boat needs some TLC but nothing extreme. Engine runs but has a rough idle so some minor work there as well. Onto the part we all love. Pictures, please click the thumbnails to enlarge.
Kohrah
Re: Introduction - New owner 16' Lone Star Runabout
More Pictures
as you can see from the pictures it still has most of the original features and items, the Bimini top needs to replaced as over the years it's shrunk and torn. The seats need some TLC and need to find someone who can redo them to the factory specs as I'd like to restore it near to original as possible. Thinking about taking the chrome pieces off and sending them out to be redone as well.
produceguy
Thats a classic. I like how the cat is poseing for the pic in pic 1.
Kohrah
Yes she is a classic and even though I have only had her a day, I love her. I see so many possibilities with her. Yes Garfield (the cat, aptly named for his coloring) decided that the bow would be a good place to start grooming himself shortly after I parked the trailer. Also the trailer is original although has been repainted red. Debating weather to restore it to the original white coloring.
mpdive
Very nice! If it were mine I would be hitting it with an 1100 wet sand followed by a thorough buffing with 3M imperial compound. OOH that baby would shine right out!
Kohrah
So I've gotten the boat into the barn to start doing some work on it, before pulling it in I decided to run the bilge pump........ and ran ...... and ran.... come to find out previous owner left it uncovered outside most of the summer. After finally getting it to point i felt safe getting in it. To provide a slightly safer work environment I was going to leave the bow down as I was going to be near the engine to offset the weight so that I didn't slam the lower unit and skeg into the concrete floor. After even more water meet me I decided that wasn't best idea. Got some concrete blocks and 2x4's and secured the back of the trailer and jacked the bow back up so it all drained towards the back.
Pulled the seats out as they are only clipped in place, shook my head at the car stereo and speakers they tried to hook up, botching up the wiring in process. get the old depth finder out that no longer worked, got the stereo and speakers out. I now need to rewire the lights as they wired the stereo and depth finder into the lines for the lights. When they made the new connections they used electrical tape and nothing else to seal the connections. Managed to get the wiring back under control, next step is going to be pulling out the old indoor/outdoor carpeting that they put in that is holding a ton of water still. Once my mechanic gets there to check the engine over I'll update more.
Am I still enjoying the boat..... as the kool-aid man would say OHHH YEA
The pile o' "stuff" from previous owner
woosterken
to save you some trouble with your top,spray the under side with water (that will allow it to strech a bit) then when its dry it should fit better.
i think you can get snap extenders here at i boats.
then just have the tear fixed.
woosterken
Maclin
Does this boat have a bilge drain hole? I was just curious why you ran the bilge pump and just not remove the plug.
If it has a plug here is a good discussion on removing it versus keeping it in for storage...:
http://forums.iboats.com/showthread.php?t=509252
Kohrah
Figured out what the previous owner did to plug the drain hole, removed that homemade contraption and bought a proper plug. People scare me sometimes. :facepalm:
