Ipad Dash Mount? Quick Release?
jakec
My mom has given me a large Ipad with cellular capability, so I want to use it for the navionics app. I have a large flat area on my dash, so I'm looking to find a case that will let me attach it securely to the dash, and quick release it leaving only a few screws or something behind on the dash. Does anyone know of a good product like this? So far everything I've found is either magnets (too weak) or a massive robot arm. I'm looking to have the ipad sit flush on the dash.
Before you mount it. take it outside and simply set it on the dash in the sunlight and make sure you can read the thing and it wont shut down from overheat in 5 minutes.
jakec
LOL. yeah you make a good point there..
JimS123
To answer the OP's question, they make a QD Ram Mount for most all applications.
I mounted my Samsung cell on a mount right in the center on top of my dash. It's in the sun and I use it all the time when running, to view my Mercury VesselView App. When we anchor I take it off and ut it in the Glove Compartment. So far, no problems. The Ram is fully adjustable, so I can tilt the screen to make it readable.
jlh3rd
Master Chief Petty Officer
here's these two Co's....but in the sun, like stated...my iphone/ipad shut down pretty quick....
maybe a shade device....
dingbat
Most cell phones are rated to 95F operation, shutdown when battery temps hit 108F.
A 10 degree difference in ambient is huge when it comes to electronics operation
Baltimore
7860May2516
8669June3020
9174July3323
8871August3122
8266September28
Buffalo
6951May2110
7558June2415
8264July2818
8062August2617
7456September23
Tampa
8871May3122
9076June3224
9077July3225
9177August3325
9076September32
jakec
In retrospect I should have realized the heat issue. On the boat my phone often shuts down (or acts weird, making calls on its own and opening apps etc) when left in the sun on the boat.
So having it point up like that probably isn't an option. I guess I will have to go with a more vertical mount then, if I am to do it at all. The problem I have is that ipad is just so large (it is the biggest one they sell). that I don't want ot block my whole dash with it.
You will have to have a shade cover over the iPad. In reality it's not designed to be used outside
