Re: Is 5200 the best
Agree- since the fitting is brass.
Just want to stress the point for other readers, that brass, bronze and stainless fittings will generally outlast the boat, so 5200 is appropriate. Chances are pretty slim that you'd ever need to replace those fittings.
If you're rebedding plastic/nylon/abs, however, use something  less permanent. Better yet, replace them with metal, THEN seal 'em with 5200..
