Is 8'10'' beam trailerable?
zach103
Re: Is 8'10'' beam trailerable?
doesn't seem to have a good amount of room for fishing
Ayuh,...
Federally speaking,... 8', 6" is the Maximum allowable width....
In most east coast states,..
8', nothing is the Maximum allowable width on 2 lane roads....
Sooo,... The short answer is No,... It's Not trailerable, without Permits...
zach103
the cabrio 220 and 240 series look like they have more room for fishing.. might be trailerable too
180shabah
You will need permits, which will also limit when you CAN tow. ie.. daylight only, no weekends, no holidays, etc...
Chiliando
I must not be understanding this correctly. My boat has a beam of 8'11' according to a what specs I found about my Hydra-Sports 230 CC. I am contstantly seeing wider boats tha mine trailered in S Florida.
Am I wrong about my beam or are so many boats being trailered in S Florida
(including my own) being done so illegaly but not being stopped?:confused:
Thanks in advance.
abj87
no ones going to bother you about 4in, we trailer our sailboat at 9ft wide with no issues.
grego
Go to DOT. and get a wide load permit, only means you need flags on all four corners,can't tow dusk to dawn and "MOST IMPORTANT!" you must stop at ALL truck wiegh stations. unless things have changed???
reelfishin
Maybe not the right answer but I had a 12' beam which I towed twice a year about 25 miles, never had a problem, I just avoided down town areas and stuck to back roads when I could and main highways were I didn't have to worry about overhead wires or parked cars.
I did that for years. The permits would have been on a town to town basis, meaning I would have had to pass through about 5 towns. I went through that moving a 42' boat years ago.
tashasdaddy
"Am I wrong about my beam or are so many boats being trailered in S Florida
(including my own) being done so illegaly but not being stopped?"
simple answer, YES. dealers also sell illegal trailers to the unsuppecting, with out brakes. there are many boats/trailers on the road that are required to have brakes, that do not. just wait till they are in a crash, who gets sued, the owner or the dealer. the owner.
Silvertip
I look at this in the same light as I do overpowering a boat. While the long arm of the law may not bother you with an overwidth load, guess what happens in the event you sideswipe someone or even worse, have a personal injury accident. There will be no compassion in a courtroom when they find out you were trailering an overwidth load without the proper permits. And to make matters worse, your insurance company may leave you out in the cold when they find out you are trailering illegally. In some states you cannot get a full time permit unless you are a mover or contractor, transporter, etc. Individuals in those states need to have a new permit with every trip. This stuff varies widly by state.
reelfishin
I was at a dealer's lot today, over 30 trailers there, all over 3500lb capacity, and none had brakes until you got over 5,000 lbs. and even a few of them were brakeless. I have had two factory tandem trailers which were overwidth themselves, never an issue or road stop.
Most of the time if your pulled over while pulling a trailer, they won't even ask about it, at best maybe they ask if it's your trailer.
I've been pulled over without a tag, with no lights, no brakes and not so much as a mention to the trailer. So long as it's not creating a traffic hazard and your not making them any paperwork, all is well.
Back when I moved my big boats, which are all long gone these days, I did so late at night, when there was no traffic and no one to bother us. I'm sure if I were to have tried it at rush hour in a city I'd have problems but at 3:00 AM, there's no one out but the bar room drunks, occasional night shift workers, and fisherman.
Seeing some of the boats being hauled around here, I wouldn't sweat anything unless it's over 12'.
I'd be more concerned about height, hitting wires is another issue, for which they would really frown upon you knocking down several miles of overhead wires.
Height is more strictly enforced than width.
magillacuddy
I would say it depends on how squeeky clean you want to be. When I owned a larger cruiser (now I have a small bowrider), and had to tow it twice per year for about 15 miles each way, I certainly took liberties with regards to the law and safety.
