Re: Is a bimini top worth it??
Hey guys,
The conduit bender can be purchased at the big box stores.  I got mine at Harbor Freight for $20 or so.  It's a nice tool to have, but I'm sure you could borrow one from a buddy that does electrical work.
It took me 4 pieces of 1/2" conduit because I screwed up the first two.
  1/2" EMT conduit is real cheap.  I measured my boats width, and just started winging it.
I found the plastic bimini end caps and sliders online.  The end caps run about $0.75 each, and the sliders were about $1.50 if I remember correctly.  3/4" bimini slides and caps fit into 1/2" EMT conduit almost perfectly.
  I think a 10' joint of 1/2" EMT runs about $1.50.
I got the canvas duck cloth at Walmart.  It works well for my first one, but I'll eventually order some Sunbrella or something like that.  My first one is already showing signs of fading.
After I got the frames bent and mounted on the boat, I used some string to hold the bimini to the width I wanted.  I then laid the duck canvas over the frame and marked it with a chalk line so I knew where to cut.  After I cut the fabric, I hemmed it about 1" all around so that it wouldn't fray, and installed small brass grommets and used zip ties to attach it to the frame.
It's held up very well to date.  I hope this helps.  I'll try to get some pictures as soon as I find my camera.
Steve
