Re: Is all Gauge Wire the same?
The concept of assigning a designator of a wire "gauge" is intended to provide a way for wire size to be measured in a standard manner. The usual wire "gauge" is the American Wire Gauge standard, usually indicated by AWG and a number For example, a wire that met the standard for AWG-8 wire would be marked with AWG-8 on its insulation. Any wire marked AWG-8 should be of the same cross section size. However, it has been reported that some wire made in Asia is unscrupulously marked with an indicator that is too generous, that is, for example, a wire marked as AWG-8 might really only be AWG-10 wire. The size of the insulation is typically increased so that the difference is not remarkable until you strip off the insulation.
The entire basis for having a standard is to provide a consistent way to indicate wire size. One AWG-8 conductor should have the same equivalent cross section area as another AWG-8 conductor. There are many other properties of wire in addition to its cross section. Wire used on boats should be compliant with USCG regulations and also with ABYC recommendations. Those specifications include other factors besides just the cross section area or wire gauge.
