Just a quick question. I put new pistons and loose needle bearings on my connecting rods today. I marked the connecting rods and caps so I could align them properly when I reassemble the motor. The problem is that after I was done, I noticed the bottom connecting rod is flipped 180 degrees or upside down. I don't think it's a problem because the manual says "either side faces up." I just want to be sure that this is ok before I put it all back together. As long as the rod cap aligns as I have it marked, it should be good to go, right? Thanks. Tink
