Fiberformboatowner
- Mar 11, 2013
- 41
I have a 200 hp outboard motor hooked up to my 19ft boat and I noticed that on the metal manufactures plate it says 150hp max is that going to cause any problems?
in some states , thats illegal. In most there is no legal issue.....someone along the line has engineered that boat to with stand the forces that a 150 hp can affect onto it...and to some measure the weight.....i am sure there is a huge safety margin. You may never incure a single issue, you may start to stree the transom... so much depends on the make of the boat and how you use it, especially how you trailer it....what year and make si the boat...and is the motor a 4 stroke or a 2 stroke?...bob
The metal tag rating back in 1976 was probably a manufacturer tag. The boat's design engineers determined what the hull could withstand. Somewhere in the early 80's (?) the US Coast Guard got into hp ratings. Their ratings trumped the manufacturer's ratings. The CG ratings were determined by a strict formula of length times width. Certainly not very scientific, and often not accurate. Today no boat dealer will install a larger hp engine than that rated on the plate, whether it's a manufacturer plate or CG plate. While not maybe illegal, there is a lot of liability should the boat ever become involved in an accident. So, while the boat may withstand the extra hp, you may not be able to insure it. As the owner, you need to assess the risk involved.
Sweet thanks for the info guys good news i live in the western part of the us so I doubt you'll run into me or vice versa![]()
Umm, isn't that what every boat owner does? I know I do. Opinions and feedback are nice and all but we do what we want.
Truth is, very few people really run WOT very often with that big an engine, Outboard or I/O. Now if he happens to go out one day and its a perfect 75 degrees, water is like glass and he's got a 5 mile straight run, well then he might push a little harder and it should be fine. I know if I had an O/B that ran and worked well on the boat I would not be in any hurry to spend the money changing it.
The iboats crowd is going to jump all over you, but it is not 'illegal' to overpower a boat, much like it isn't illegal to add more horsepower to your car... Also, insurance generally doesn't care what the plate in the boat says.
