Is their an advantage to having through transom exhaust?
Status
Not open for further replies.
krisnowicki
Re: Is their an advantage to having through transom exhaust?
I say if you have thru hull put them in the water at mininum. I had a liberator with thru hulls above the water line and when we came in at night the whole neighbor hood would wake up. I felt like such a D*^K but, with the ehaust going out the side and under the water it makes a huge difference. at least when not on plane.
HT32BSX115
HEY! How are you coming on the OMC/Merc Swap?
Pictures?:D
HT32BSX115
Like the guys over on speedwake with HUGE power, and by huge over 6-700 hp
I think it would make a HUGE difference then.....
You know, I still do have the "holes" in the back of my Liberator.............I still have the Capts Call too. If I can find a decent set of mufflers like below....I may hook them back up.
These are something like $800 though :eek:
picklenjim
Takes more than a paint job and some chrome to get me excited anymore.
And you REALLY read the question, you will see there is nothing in it about performance. The point of the question was BELLOWS.
Paint and chrome on a boat never excited me either. Seven color factory gel kote graphics and stainless steel, now that excites me! Especially at 85 mph.
As far as the "point" of the question the question was is there an advantage to having through transom exhaust. Answer yes....performance.
TowRoper
:mad: this whole thread is a joke on one hand we have respectful people who care what image boaters have by not being a nuisance on public rivers and lakes and on the other hand we have the wanna be speed racers that think more noise means speed and don't give a rats a** about the public around them cuz they are #1 in there own minds, its a dead end talking to these people cuz there mind set is noise gets them noticed what seems to be more important to them then actually going fast maybe one day they will figure out what they are doing and build a boat that is fast as hell but wont kill the water experience of the people around them.
Ayuh,.... Only after you blow a wad of Ca$h on Headers, rather than Manifolds is there any kinda Performance advantage....
The next time the motor comes outa My barge, the Y-pipe is goin' Back in.....:rolleyes:
wca_tim
it can make a bit of difference even once you get somewhat above a stock smallblock and especialy if you're turning more rpms... Bond-o tagged the main issue above - the exhaust isn't the bottle neck with the stock system. even stock marine engines are running pretty close to the design limits of the combination of heads, cam, exhaust manifolds, riser, y-pipe and prop. so if you don't open up all of the places that restrict airflow through the engine, there's no gain. put decent heads, cam etc... on the engine, and now the exhaust manifold is the bottle neck. it isn't until you go to either good performance manifolds (emi, imco powerflow or stinless marine) that the rest if the exhaust becomes the bottle neck. by the way, i'm not even close to big power but am a good bit above a stock merc 350 or 454, and the stock flame arrestor is worth 200 rpms at wot. Both sets of the cheap mufflers I tried first made a difference of 400+ rpms at wot and didn't quiet it down the way I really want it to be. now we're going with better, higher volume mufflers (that have been dyno tested with well over 500 horsepower) and turn downs to redirect the sound just a little bit and it'll be right where it needs to be with only minor if any power loss.
the other issue is, how much do you really run your boat where the exhaust will make a difference in performance?
which brings me to the noise issue... I can see why folks like the wide open exhaust, but if it is set up so you can hear it in the boat, it gets annoying in a hurry - especially if you're pulling boarders or sliers, listening to music and cruising rather than running hard. and sure it can be annoying to others, but if you set it up right there's no reason it can't be fairly quietat idle and slower cruising speeds. Personally I like it with a nice rumble, but with plenty of silencer /baffle to take all of the sharp edge off it. more like a good set of performance auto mufflers (not glass packs) sound behind headers...
to the folks that don't want to hear it on the water.. If you're on a small secluded lake or river, or if you are off and fishing in the lower traffic out of the way places, then by all means I'll steer well clear and slow down if I'm going fast enough to make a lot of noise (and if we're where we have to pass close by, I'll set speed on whatever I'm driving to make the least amount of wake at a safe speed), but if you're right off the channel in one of the main areas of the sound or river inlets, or if you're up in the couple of main river areas where the high performance outboard guys are often playing, you got nothing to gripe about. At least where I'm at, there's an awful lot of water and soooo many places where there are seldom people flying by very close in loud boats. if you want quiet wind up in the many many more secluded areas. Part of it probably has to do with where I live and play the most, but that's the way I see it.
addition: if you;re pushing a drive hard, the heat from the exhaust going out the transom rather than heating the upper gearcase makes a major difference...
45Auto
I'm sorry Tim, but logic is NOT allowed in these discussions. I'm sure a moderator will be along shortly to delete your post ......
:D
Maclin
Advantage? Yes. You do not have to hear all the annoying verbosity going on inside the boat like "SLOW DOWN!" or "TURN AROUND! BOBBY JUST WENT INTO THE DRINK!". This extends into the first 20 minutes or so of exiting the boat as well.
Status
