Is there a way to run a two stroke kicker ?
JJB
If I have a 4 stroke engine and wanted to use a 2 stroke kicker that I have . I wanted to use my main gas tank for both . Is there any device that is out there that let me use my 2stroke kicker with out taking a small tank with me ? Thanks JJB
JB
Re: Is there a way to run a two stroke kicker ?
Please identify the engines you are talking about.
WillyBWright
Johnson/Evinrude used to offer an inline device called AccuMix. I don't know if it's still available. You might be able to find a used unit at eBay. Also check with dealers. Most have taken such units off and set them in a corner to collect dust by now. Mercury had a unit called AutoBlend, and Merc dealers probably have stacks of them lying around, if they haven't been tossed. They had a bad rep.
tashasdaddy
basically no. the above mentioned mixers ruined a lot of engines. if the kicker has a separate oil tank,(oil injected or vro type) like some of the older small hondas, you could do it.
bassboy1
Some older kickers have built in tanks. You may want to investigate that if your problem is the space for another tank.
kenmyfam
I think taking the other tank is the best idea
