Is there such a thing as peeing too hard?
billhig
Is there such a thing as peeing too hard? After I got my OEM water pump installed and a blockage removed, my '79 40 HP really pisses hard. It shoots out straight a good 5 ft. This is dead cold with the thermostat not open yet. The engine is turning about 900 RPM. Does this indicate a problem or am I just paranoid? I tested the thermostat and it opens at 145F. I replaced the poppet last year.
Chris1956
the device is called a telltale, because you can see it. It does not affect cooling.
What is the water pressure on that hose?-----Test it on the lake I say.
