Re: Is this extra leaf spring install right??
You are going to get a lot of personal preferences on this one. If you go look at boat trailers, you will probably see as many axles over the springs as under. It's a matter of height requirements. Also those springs are quite long, they are not trailer springs, they are for some auto application probably. Around here we call that extra spring a helper spring and they are usually only found on larger trucks. Will it work, sure, do you need it, time will tell. If you are going to use it, I'd probably turn it around so both ends were equal distance from the frame. One thing for sure, those longer springs will probably give you a bouncier ride without shocks to dampen the rebound. Also, someone mentioned if you do flip the axle under the springs to just roll it so the perch fits against the spring, be careful, some axles are arched for the camber. If you roll it when you move it you will affect the camber and cause tire wear if it is an arched axle.
