Is this prop "fixable?"
Fishermark
I have a SS prop that I had on my Mercruiser a few years ago. I bent the prop up pretty badly while motoring onto the boat trailer - it hit the ramp! :eek:
I have kept it up on a shelf intending to get it checked.... but haven't gotten around to it yet. There is a prop shop about an hour away from my house, but before I drive over I thought I would check here to see what you think. Is this prop able to be fixed? My biggest concern would be where it has bent over, there are noticeable stress cracks:
Fordiesel69
Re: Is this prop "fixable?"
A shop can reweld it, but unless it is a very expensive prop, it isn't worth it. $89 for the solas brand, and $55 plus material and tax here locally to get one refurbed. Simply not worth it.
A 500-600 dollar prop would be worth it.
Brewman61
Ensign
I've emailed photos to my prop guy a couple times- he can usually tell by the pics if the prop is rebuildable.
AL props are amazingly rebuildable. Not sure about SS, as I've yet (Knock wood) to crack one up.
NelsonQ
My SS cost $800 bucks so I'd go repair however the stress crack may be the issue.
drrpm
SS is even more fixable than AL and a lot more valuable. It may be worth a trip to the shop. That's the only way to know for sure.
Fordiesel69
Where are you able to find a Solas stainless steel prop for $89?
You can't. I mean you can buy a replacement prop in a solas brand for $89. Why rebuild this one? Sometimes AL props will save your lower unit when you hit.
Honestly from the pic it almost looks black. I thought it was AL. It must have been one heck of a hit to bend that up like that.
