Is this thru hull exhaust too low on the transom?? Check the pic
dnsellers
Re: Is this thru hull exhaust too low on the transom?? Check the pic
Heat problem??
Richard Petersen
Tommays, My boat has 5 times the engine space of his. Rich. There's enough room for a 5.7L. :D
tommays
Derek<br /><br />the heat is only a problem if you dont allow the motor to cool down after a long run before shuting down and dont use the bilge blower at low speeds<br /><br />the motor box can get hot enough to cause a lot of vapor lock problems on some boats <br /><br />you need a closer shot of how the riser is conected to the through hull which this shot does not show<br /><br /><br />tommays
