dingbat
- Nov 20, 2001
- 17,094
The starting battery is primary and isolated in the system. The house is the slave.Sure, just flip the battery switch to BOTH. With a two battery setup isolated via ACR, I suppose much of this is academic. The real advantage of that kind of system is that if one battery is drained, for whatever reason, the second battery is isolated until you choose to combine.
The system works well, but there is no guarantee as to the condition of the house battery at any given point.
An under charged or failing primary battery may never reach the voltage threshold to open the ACR to charge battery 2 and you would never know it.
The first sign of my impending problem was my sonar display acting up. Shortly there after my tach started acting up.
Combined battery 2 with battery 1, which I later found out was shorted internally. Tow Boat shows up 3 hours later to tow us back from 17 miles offshore.
Cost me a battery, a voltage regulator and 4 hours of labor to install and wire a remote indicator lamp at the helm to monitor ACR combine status.
I have since installed a second volt meter to monitor each battery independently as well
Learned my lesson on combining batteries of unknown condition as well
