Issue with flooding on Weber Carburator
Scott06
The fuel pump should function like the mechanical ones you are familiar with from back in the day- should supply 6 or so psi to the carb -I suspect you have more pressure. Measure the fuel pressure by finding a way to put a T in the fuel line and use a simple vacuum/ pressure gauge available at any auto parts store. If the pump is supplying more replace it with the correct low pressure (carbureted fuel pump). There are low and high pressure pumps for mercruiser engines (carb vs fuel injected) possible some one installed the wrong pump
NHGuy
It sounds as if your pump has too much pressure. It may have failed in a too-powerful-supply way. It should send about 6 or 7 lbs of fuel pressure to the carb.. Any more and it can overcome the needle valve that the float closes.
I'd get a gauge on it, then you'll know. Don't just install the pump til you are certain.
I'm glad to hear that you are using the right switching to manage the pump operation.
Good going.
And to answer your question about when the pump runs, it runs constantly when the key is on and oil switch has pressure. On my engine if I have serviced my carb and I crank the engine for a few seconds, the oil pressure comes up. I can then pause while the pump runs til the oil pressure falls off. Better than long cranking in my opinion.
I have mine set up kind of hot rod 'ish. There's a marine pump wired and color coded like Mercruiser, it has a solenoid operated power supply. Then there's the fuel water separator, a fuel pressure regulator, a mechanical gauge and the carburetor. I went overboard with all the extra bits because I didn't trust that the pump had the right pressure. And I was right, it was high on the pressure. So now I can look and be sure everything is correct.
And yes, you will have to remove spark plugs to get that fuel out of the engine.
alldodge
A carb fuel pump should output 3 to 7 psi, any higher pressure and the needle valve will be over powered. The pump will always run so long as the motor is running and the carb will stop the fuel so long as pressure is within range.
Pull the plugs and disconnect the fuel pump, then disconnect power to the coil and crank the motor over to expel the gas
achris
More fish than mountain goat
...My question is does the fuel pump run at all times or does it cut out once the floats close?...
The oil pressure switch that feeds the pump is closed, supplying power to the pump, any time the engine is running. So the short answer is 'No, the run does not shut off'.
It's exactly the same as a mechanical pump. While the engine is running, the pump keeps stroking. Internally the valves hold the diaphragm up if there's no flow. But the instant the fuel level in the carb drops and the needles open, fuel flows in. Just like the electric pump.
If your electric pump is running when the engine is not, and it sounds like it is, then you also have a wiring problem.
Chris......
Gerhard Peters
So it was the fuel pump. I should not have jumped as fast I as did to buy the carburetor. @
jimmbo first post suggested that it fuel pressure may be too high. I put the tester to the pump and it went up to 45 PSI. Installed the new pump and is is now at 3-4 PSI.
I will keep the new carburetor and sell the other one on ebay next spring when the demand will be higher. I rebuilt so it should be a good carburetor for someone.
Rick Stephens
Good news. Nice to find the beast. If you are going to a new carb, do take the time to check calibration. Run it at several different throttle settings for a 8-10 minutes each, each time do quick shutdowns and pull to check a couple spark plugs for richness and especially, leanness. Check accelerator pump and needle valve action by accelerating for idle and from cracked throttle conditions. These are all easily adjustable using the Edelbrock calibration manual for that carb.
Lou C
sounds like the original pump was for an efi system!
Scott06
Good it’s fixed and was except for buying new carb relatively simple. It usually is the simple stuff. Hopefully you can aell
one carb or at least you have a working spare ..,
