What would cause a problem when I start the motor after a few seconds it stops and if i do get it going I put it in gear and it stops. Would this mean that the fuel filters might be clogged causing not enough gas to pass thru. I was just using the motor 2 weeks ago and it was running fine. I changed to another gas tank used for my kicker motor in case their might be water in the tank no change. Possibly a bad fuel pump. Any help would be great thanks.
