oldboat1
- Apr 3, 2002
- 9,612
A length of weed-whacker line makes a useful too to clear the tell-tale passage. If the trash you mentioned looks like very fine sand, it is probably part of a mud dauber nest. (In any case, you might pull off the lower unit and pump some water up the tube -- see if that helps. Check the lower unit water intake as well.)
