Jason,<br /><br />How is that Skid-No-More holding up for you?<br />I am considering using it on my deck.<br />I have few questions for you.<br />Did you apply with a roller or brush, or spray?<br />The directions do not mention using a roller, they say to dump it out on the deck and spread it around.<br />Did you thin it at all with water as the label suggests?<br />They also say you can mix it 2 to one with a high quality exterior latex to change the colors.<br />Finally did you just use it on your deck, or on the side walls also? Would it run on a vertical surface?<br />H90
