CalicoKid
- May 27, 2002
- 1,599
Last post I was looking for a stainless prop for my 15.5' Javelin. I've since purchased a Stiletto Triad for it. With my OMC aluminum 17" pitch prop I was getting 33mph@5600rpm at best efficiency. With the stainless I am getting 33mph@5400rpm at best efficiency. To determine best efficiency I am watching my gps and tach while slowly trimming out and stopping trim out at the point at which speed stops increasing but rpms continue to increase. I think I need to be getting more rpm out of this motor.
Boat and motor are 1992; Javelin 350 angler 15.5', Johnson 40hp twin.
The hull is quite light. It has a built in setback of 7" but no pad. I think my motor is much too low, the AV plate is about even with the bottom of the hull (not the bottom of the setback). I am getting a lot of spray between the transom and motor bracket. How far should I theoretically be able to raise the motor? Since a pic is worth a thousand words, here's a few grand worth:
