Jegs vortec heads
carlos515
I assembled my motor and was about to install it in the boat when I came across a YouTube video regarding cylinder heads for marine , castheads.com.
My question is , do I need to replace my exhaust valves with inconel or equivalent valves? I believe the valves are standard type. I have a stock 355ci with a chevy marine roller hydraulic cam and flat top pistons.The engine is a 1995 chevy 5.7l.
Thanks,
Carlos
  • Screenshot 2022-11-05 at 11-40-13 JEGS 514080 Small Block Chevy Cast Iron Vortec Cylinder Head...png
Run inconel only if you are running a supercharger
Not needed for your motor unless you like wasting money
