johnson 115 81model compression
hypo069
Hey guys i have a 1981 model johnson 115hp, i recently did a compression test- left side - 120, 118, right side - 115, 107,,,,does this sound bad?
kenmyfam
Re: johnson 115 81model compression
Should be even and within 10% of each other. Give it a decarb and check it again.
Welcome to iboats
hypo069
I just put oil into the cylinder that is low 107psi and it read 115psi, after testing that cylinder about 5 more times it went back to 107psi so i presume i have a worn ring? any suggestions
SparkieBoat
do a decarb..instructions in the secret files section at top of forum..if that does not work you can try resurfacing the head and replacing head gasket.
kenmyfam
May just be a "sticky" ring. Decarb as suggested and re-check
emdsapmgr
120 to 125 was probably normal compression when it was new. These crossflow engines are prone to accumulating carbon around the rings as they get older. Carbon buildup will affect (lower) the compression readings. I'd follow all the prior suggestions about doing the decarb before you get too concerned about the compression readings. If needed, a second decarb may help further. The decarb process should also improve the idle characteristics and improve cold starting. It is also typical that the compression on these crossflows can vary 5-8 lbs between the two heads-due to the way the blocks were originally manufactured.
hypo069
Cheers guys, you have been very helpful, i will be doing a decarb on the w/e and will let you's know how i went.
