Thank you - will check fuel pump. What is the spec compression for this motor?
Q Qrythm Cadet Joined Jan 4, 2025 Messages 12 Jan 4, 2025 #21 Thank you - will check fuel pump. What is the spec compression for this motor?
S saltchuckmatt Captain Joined Jul 19, 2019 Messages 3,055 Jan 4, 2025 #22 100 to 140 psi and within 10% of each other. Some might say even slightly lower. Your right down the middle...should give you years of service.
