Johnson 115 V4 Seahorse 1978 model.
tomnt1
I've aquired this motor on an old Glastron ski rig. It looks fine but hasn't been started in six years. The # is 115ML78C, what does the M stand for?
OBJ
Re: Johnson 115 V4 Seahorse 1978 model.
The "M" means manual tilt Tom. You might want to check out the FAQ section on the main menu. There is a real good read there called "Awakening A Sleeping Outboard". Check it out.<br /><br />And....Welcome to iboats!
Solarex
hi tom, did you had any luck reviving your 115 motor? i just picked up this same motor from a donor boat, same model number too.
