trobinson017
- Sep 12, 2004
- 183
I have a circa 1999 Johnson 130 Oceanpro outboard. I'm the original owner, having bought the boat from a dealer that got it from a bankruptcy sale in 2003., so I've owned it almost 5 years. The engine has about 200 hrs on it (not positive tho, no hour meter). I just learned I should check/replace the tilt/trim fluid in the reservoir. My engine manual says to drain it and fill it with new fluid so it's level with the plug/cap when the engine is at full tilt. I tried to do this yesterday. The reservoir cap is at the bottom of the reservoir. When I unscrewed the plug fluid started dripping out. I screwed it back in as this didn't mesh with what I read in the manual. It just doesn't seem right to me that the reservoir appears upside-down and that fluid leaked out when I unscrewed the cap. Am I being paranoid or should I just go ahead and drain it out and refill to the cap level per the manual?
Any advice for a newb?
trob
trob
