hi everyone my j140tlcte have to push key in 3 or 4 times to keep it running at cold start runs real good on top end been rebuilt about year and 1/2 any way the guy that rebuilt it turned the little thumb wheel to adj. idle it worked fine some time later it started idling about 1200 rpms and oll me turned the thumb wheel didnt lower idle could that have changed the throttle pickup timing?
also i have different advice on which plugs to use currently using ul77v flat tip and i notice some fuel on the water no visible leaks maybe front of carb
