Johnson 150 GT V6 Takes 45 minutes to cold start
clanton
Re: Johnson 150 GT V6 Takes 45 minutes to cold start
After you get the primer solenoid working, the hoses and nipples are clear. Fuel is flowing when key pushed in. Drill the primer nipples out to .062. Engine is 1987.
Check the purple/white wire on the solenoid, should have 12 volts, when key pushed in.
