Johnson1585
- Aug 14, 2009
- 3
I read a thread by bluebunny SS from April 13/09 and was hoping for a conclusion because it is exactly what happened to my friends CJ15RLCO motor. We puttered on the chuck with the motor and as we opened it up it over heated. I went to replace the pump/impeller and noticed it was in good shape except for the grommet had a small tear so I replaced it and reassembled and started it. It still dribbled and as I applied gas it began to trickle. Not good enough, so I replaced the whole pump. I sprayed water through the copper pipe and water streamed out the pee hole nicely. I checked the intake and it was clear. I assembled the pump reusing (#40 on the gearcase diagram) the plastic sleeve and did not add the O-ring (it looks like it is only used on the 5" extension model). I put the impeller in the same way as the old one and understand that it would correct itself if it was put in wrong. I did not use any sealant (I understand you don't have to) and did grease the shaft. I aligned all parts and it I fit the LU together with ease. I fired it up and it still just dribbles. The 3" hose to the pee hole is in good shape. Help!!!
