I can't get my outboard to shift into reverse under engine power. With th engine off, when in neutral, the prop spins freely. With the engine off, when I shift it into reverse, the prop will engage and I can't turn the prop. But when under power, the prop will not catch in reverse. Everytime since I bought the used engine (for 4 months), it would not go into reverse. Except, one time last week, I was able to get it into reverse just after I started the engine!!!! I was so excited I couldn't believe it, but when I went into forward and back to reverse, no luck. I have adjusted the thumbwheel all the way to give me maximum reverse linkage travel. I've even taken a broom handle while underway, removed the engine cover, and tried to push the shift lever on the engine into reverse, but no luck. Any ideas????
