i am about to put an untested 1957 35 HP johnson javelin in the water on a newly restored boat tomorrow (7/15/06)
the motor has not been run in 2 years (it was overhauled at that time). I dont know what 'overhauled' means, but I assume it means new impeller, plugs and a verification that it'll start. the previous owner said that the motor ran like a top (which is comforting)
the electric start hasnt been run in 20 yrs. I am going to give that a go. If it's not functional, I'll be pulling the recoil.
I have some rabbit ears to test it in the driveway before I put it in the water. should I do that before it goes down the ramp (i have a paddle).?
I'm a wood guy more than a motor guy, so any advice would be welcomed.
the previous owner also mentioned that I should check the level of the lower unit and add some more oil if necessary. can I top off the lower unit rather than flushing the entire lower unit? how do I validate the level is ok? just check from the top screw that there is enough oil?
btw.
photo today:
http://img.photobucket.com/albums/v357/robotgoesnuts/boat/P1010002.jpg
btw.
photo today:
