Johnson 35 HP No Power
rick_l
I have a Johnson 35hp motor mounted to a patoon boat. The first trip to the lake, the motor started fine but had to run with the choke out to keep the motor running. When I got home I boiled the carb out but did not put a kit in it. The second trip to the lake, the motor started fine and ran great. After about 5 minutes of running 3/4 throttle, it bogged down again. This time I did not have to use the choke, but if I pushed the throttle too far it would cause the motor to bog down more. What does everyone think....ignition problem, fuel problem, head problem. Any help would be appreciated.
rick_l
Re: Johnson 35 HP No Power
So you believe that it is a carb problem and nothing else. Could a power pack be breaking down?
tashasdaddy
yes, i believe you cleaned the carb enough for crap to get into the jets.
