Re: johnson 50 hp hydro electric problems Please HELP
The next thing is to stop calling it a relay - its a starter solenoid. The reason why I am being insistent about this, is that you have to try to use correct terminology, so that people understand what you are talking about.
After that, try to be precise in explaining what you did. When you say that you measured 0 voltage on the starter, or downline side, of the solenoid, with the key switch "on," do you mean merely in the "run" position or the "start position."
If the key switch was only in the "run" position, you would not get voltage on the downline side of the solenoid. On the other hand, if you did turn the key all the way to the spring loaded, "start" position and did not get voltage on the downline side, you have a problem. If this happened with two different solenoids, you could have a problem prior to the solenoid.
Since you were getting solenoid clicking at one point and are getting nothing now, the first thing that I would check is the inline fuse, which should be located on the starboard side of the powerhead. I don't have a manual on your motor, so I can't tell you exactly where it is, but its probably right above the powerpack (rectangular box with wires on both sides) and near the wiring terminal block. Look for an oblong rubber casing that comes apart - the fuse will be inside.
If the fuse is blown, replace it with the correct 20 amp fuse. Its very short, so I don't know if you can get it in an auto parts store. If so, your best bet will probably be a NAPA store, because they do stock some OMC marine parts. Otherwise, you will have to find an OMC/BRP dealer or some other source of OMC parts.
If the solenoid tries to work after you have replaced the fuse, but still clicks, go back to F R's advice. Solenoid clicking is a sure sign that not enough amperage is flowing to fully actuate it. That comes from either a weak battery or corroded connections. If you need to clean the the battery cable connections, clean all of them, including the ground wire connections. Don't forget the cable between the solenoid and the starter. The starter grounds via the mounting bolts and you may even have to remove one or both of the bolts to clean it/them and the surface of the starter flange(s).
Do all of this and let us know how you are making out.
