Johnson 69 55hp stuck in fwd
F_R
Blocking diode---supplies 12V to shift switch when key is turned on, If diode is backwards, or replaced with a plain wire, the motor will not shut off.
jredman941
Thank you, all of that helps me troubleshoot
jredman941
Because of your help I was able to locate the problem, the wire for the diode was removed from the ing switch, thank you very much for all of your help.
