Perspective
- Nov 12, 2017
- 23
http://ww2.iboats.com/Carburetor/dm/...iew_id.1546130
And…the roller has to contact the cam at the indentation/mark — carb throttle plate should begin to open at that point in the timing advance (the “link and sync”)
oldboat1, you're awesome, you clued me in to my problem. I'll get to that in a second.
So I fixed the high speed issue. When I replaced the small hose in the carb I cracked the bowl and replaced it. While doing this I missed the small gasket under the high speed nozzle. Well the high speed issue is resolved but now I have stall when idling down.
After reviewing your post I realized that I had a nice gap between the roller and the cam around the notch and made the necessary adjustment. Much improvement but still stalling when idled down. I guess I lost adjustment when I disassembled it or someone in its past life adjusted it as the carb got out of adjustment.
Is it ok to keep adjusting the roller cam until I get no stall or is there a better way to prevent the stall?
Thanks!
