Re: Johnson 70hp - How fast does it push your boat?
My boat is about 2,000 pounds loaded in my typical configuration, which includes boat, motor, 24 gallons of gas, three coolers which double as seats/storage, gear and my big ole fat butt. If I take a guest or a couple of models for a photo shoot, its heavier.
As for configuration, I'd call it a shallow V.
My last trihull was also a Glassmaster and had a pair of 1958 ERude 35hp motors on it at one point. Those motors really only deliver something a little less than 30hp to the props and the dual engine setup results in more drag than a single engine installation. I had 14" pitch props on the motors for this boat.
Since this boat was 15.5 ft in length, I would say that its closer to your boat in weight. If I remember correctly, the empty weight was about 800 pounds. Add 300 pounds of motors, 24 galllons of gas, gear, etc. and the operating weight would be about the same as your boat.
With probably no more than 58hp total HP to the props, plus the added drag, that boat probably ran at least in the mid 30s range. I never checked it via GPS, but it was considerably faster than my present boat.
You mentioned that your 85hp Force used to push your boat at 38-40 mph and that it is rated at the powerhead, not the prop. If the 70hp that you want to put on it is rated at the prop, I see no reason why you shouldn't get about 35 mph out of it, as long as you prop it correctly.
