Hey All, was out on the boat a couple weeks ago and trim tilt stopped working and had to use the manual hydraulic release to trailer the boat home. Ended up testing the hydraulic motor directly and worked immediately. Jiggled the relays and things started working again from the controls. Ended up replacing the relays and things work now but have a concern as going up just seems slow and off. I added fluid and didn't take much. Also tried multiple times adding and making sure air isn't in the system. Does it sound like the motor is just dying? I also greased the pivots on the steering tube. I don't want to start taking things apart unless I am sure that's what's needed. We all know how many bolts can snap. Here is a video, any advice here would be great. Might not need anything.
