I have a 1986 90hp Johnson that I just repowered my boat with. i purchased it used from a guy, he started it and it ran ok, and then he turned it off (by the ignition switch). I just put it on my boat and started it just fine, ran good with no problems, except when I went to turn it off, it will not turn off. I disconnected the battery, still runs, so i finally disconnected the fuel line and waited for it run out of fuel. anyone know which wire kills the motor on this engine so I can verify it is connected correctly? I have a manual but it is kind of hard to decipher, it looks like everything is as it should be.
