OK , finally got everything done . The carb was actually clean so I cleaned it again got it done , made special care to get it right since its quite a pain to get it off . Anyway I got it rigged up to try . Now when the lines are full of gas , it will pump right through the carb. I was very careful to get the float in right and checked it for levelness too . Im at my wits end here cause I can't think of anything other than the float or needle valve . Is there something this old imbecile is missing ? BTW new fuel pump is on the way too .But again I'm certain it's right or at least what I've done . A million thank you'd in advance . You guys are great!
