Johnson cylinder sleeves
rcb130
PLease, does anyone know the answer to my questions below?
Hello,
I have a 1995 Johnson 150 Hp V6 carbed Model J150GLEOM I am working on. I have two questions:
1. What is the cylinder sleeve material and is it hardened?
2. On each cylinder head next to the middle spark plug there is a tapped hole that goes to the water jacket. What is the purpose/use of
these tapped holes? Mechanical water gage or temp?
Thanks in advance for the help.
rcb130
Re: Johnson cylinder sleeves
RCB, Normally cylinder sleeves are made of cast iron. I do not know if they are treated. If the tapped hole is into the water jacket, you may install either a water temp sender or a water pressure gauge. I like the pressure gauges better as you can anticipate the wear on the water pump better.
bob johnson
I also believe all the sleeves are cast and NON hardened.....there are probably two threaded holes....more techinically ...one is a hole and the other is a bore. the hole is for a water pressure gauge pick up...the bore is for a temperature gauge sender. on the V4 the upper one is the sender for temps, the lower one is for the water pressure....not 100% sure on the V6 motors . I bet they are on either side of the temp SENSOR threaded bore.....which is between the top plug and the middle plug on the V6
bob
rcb130
Chris and Bob,
Thanks for the information. It is greatly appreciated.
rcb
