Johnson Fdl-19d 18 Hp
adidas
Hi
My JOHNSON FDL-19D 18 HP has some old parts.
I have took a picture of these parts since I dont know their name.
can someone please identify the parts and give me a link to a place where I can buy new ones?
thanks a lot
adidas
Sea18Horse
Re: Johnson Fdl-19d 18 Hp
Ignition coils, Sierra p/n 18-5181. Normally right here at iboats would be as good a place as any. Unfortunately they show they are currently "out of stock". laingsoutboard.com is another good spot. Of course you can also get them through your local Napa or CarQuest auto parts store but you will pay a bit more and you'll need them to order them in for you. And the kid behind the counter will likely look at you like you've grown horns but they can get them.
You might want to think about points and condensers too. P/Ns 18-5156 and 18-5199 respectively.
Cheers..................Todd
Sea18Horse
Well there ya go! :)
Edit: I wonder why that page didn't come up when I typed 18-5181 in the search? Instead of the page that said they were out of stock. :confused: Overly complicated web pages! :(
Cheers.................Todd
adidas
thanks for your last answers!!!
In addition...
what would be the parts number for the corresponding coil cables and for the impellor for the same Johnson Fdl-19d 18 Hp motor?
F_R
In addition...
impeller (alone) is 18-3002. repair kit is 18-3203. pump kit is 18-3377
Coil Cables?? You mean spark plug wires?? Best to get them locally. But make sure you get "wire" wires. The carbon string core stuff used on cars won't work. However, iboats does have 18-5225 which is a 25 foot length of wire plus a bunch of useless terminals which you will be throwing away. The boots for the ends are 18-5750.
