Johnson Outboard.
INJUN JOE
I have the opportunity to buy a Johnson Outboard for $60. It has an electric start. The seller says it needs a water pump. The guy who has does not know any of the following.<br />1. Year of Motor<br />2. Horsepower<br />3. 12v or 6v<br />4. is a water pump availiable for this unit.<br />5. If that is all that is wrong with this unit is it a good buy.<br /><br />If anyone could help me with any of the above information it would be greatly appreciated.<br />The model # on the motor is RX-105<br />Serial # is 2303818 <br /><br />Thanks Much!!!<br /><br />Joe :confused:
Joe Reeves
Re: Johnson Outboard.
1. Year of Motor = 1962<br /><br />2. Horsepower = 28hp<br /><br />3. 12v or 6v = 12v<br /><br />4. is a water pump availiable for this unit = Yes<br /><br />5. If that is all that is wrong with this unit is it a good buy = Yes<br /><br />6. Fuel mixture = 50/1 - 87 octane is fine
moderator1
Can anyone tell me what year , horse power and volt and gas/oil miture the following Johnson is??<br /><br />Serial# 2303818<br />Model# Rx-10R<br /><br />Thanks Much!!
alcan
Hi moderator<br />My year model guide lists your motor same as the one above.
Hooty
In fact, it even has the same serial nr. :confused: <br /><br />c/6<br /><br />Hooty
D
DJ
Guest
Hooty,<br /><br />That's odd! You missing a motor??
