Just acquired two Johnson QD 19's in a one week span. The first is seized but I picked it up for parts in anticipation of the second QD 19 that mostly runs. The second has a broken shifter rod but otherwise runs well. Turns out both the upper and the lower shifter rods are in bad shape and severely corroded. My initial plan had been to simply take the shifter rods from the parts engine and install them in the second but the level of corrosion on the rods is troubling me. Is this an indication of something else wrong? The water pump and drive shaft are in good shape and the top and bottom end of the shift rods are pretty clean as well but the middle section, by the access panel, are brittle and half the original width. The bolts in the connector are unrecognizable as well. Should I alter my plan from just swapping the rods to swapping the whole mid section of the engines?
