Can anyone advise me regarding the various alarm sounds on the remote horn.<br /><br />My engine sounds an intermittant beep when on low revs when it,s hot. What does it mean. The water coming out of he engine is not very hot, so I don,t think it,s overheating, but it,s a worry.<br /><br />I,m also having trouble with the power trim.It,s not working most of the time.<br /><br />I seem to have tracked it to the small black box which is attached to the engine. Inside there are two relay boxes which make a high pitched squeak from time to time when the trim does not work. I suspect either these are faulty or there is a corroded contact somewhere. Can anyone advise?<br /><br />Thanks in advance,<br /><br />Brian
