Johnson versus Evinrude Parts numbers
RockRiverene
I'm looking for a shift lever for a 1958 FD12 18hp Johnson. I found one for a 1958 Evinrude Fastwin 18hp.
I'm thinking that they should be interchangable, but I see they have different parts numbers.
Does anyone know if they used different parts numbers for like parts used between Johnson and Evinrude back then?
Thanks.
Steve
katman123
Re: Johnson versus Evinrude Parts numbers
RockRinerene that shifter should work, I to have a johnson 1958 18ph I am working on and I am using the shifter off of a 68 Evenrude I have found that most of these motors are basically the same motor, if you want an original though try your local NAPA stor that is were I buy the parts for my 58 and 63 johnsons
